89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Gutter End Caps
Mon, Nov 26, 2012 at 10:33:19 AM | Gutter End Caps
KposK17
5 Stars: 2 Votes
how would i go about putting endcaps and drain spouts on to my gutters?
Mon, Nov 26, 2012 at 10:59:42 AM | Gutter End Caps
3.5 Stars: 396 Votes
Read similar threads below.
Mon, Nov 26, 2012 at 11:15:48 AM | Gutter End Caps
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes, as WW indicates we should always research the existing threads here first. Quite often the answer is there. Use the search pull down from the top of this page.
Out of the box there is no components for gutter end caps and down spouts (last time I looked anyway.)
Is a nut shell the end cap can be an in-place or external external family that is a generic model face based. Probably use the gutter profile for the perimeter and an extruded thickness of 3/16"" (5mm) etc.
The down spout could be a n in-place family 'sweep'. Don't worry about making the downspout hollow. Just make a solid sweep. Getting the correct workplane will come into play when creating the sweep path.
An external family of a down spout is also possible but I use in-place families becasue the conditions usually need to work with the local geometry.
gutter end caps
Thu, Apr 21, 2005 at 7:21:29 AM
End Caps
Mon, Dec 14, 2009 at 1:28:08 AM
Anyone got an easy way to cap the end of a gutter sweep? Anyone?
Wed, Feb 14, 2007 at 7:22:46 PM
gutter caps and down spouts
Tue, Jan 23, 2007 at 9:07:32 AM
ductwork end caps
Fri, Jun 19, 2009 at 6:08:04 PM
Page generation time: 4.9402
