64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Trouble with creating a Ribbed Groin Vault
Sat, Nov 24, 2012 at 5:52:10 PM | Trouble with creating a Ribbed Groin Vault
Memmelle1
1 Stars: 1 Votes
I'm trying to create a ribbed groin vault and am stuck trying to 'trim' it as I'm building it. I've created the rib sections as walls with arched
openings in them and the first portion of the groin vault barrel ceiling as an In-Place component. I need to trim out the web portions
between the ribs so that I can create another barrel vault 90 degrees to the first one. I don't think I can use the shaft
function to trim or cut out the webs. In the attached images, the red X webs are the ones I need to cut out.
What are my options? What do I need to do?
Sat, Nov 24, 2012 at 7:58:19 PM | Trouble with creating a Ribbed Groin Vault
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Im not 100% sure what you are trying to do but it sounds like you need to use an In-place family, 'Void' and the cut geometry tools.
Sun, Nov 25, 2012 at 6:56:54 AM | Trouble with creating a Ribbed Groin Vault
4 Stars: 203 Votes
DG is correct, edit that "in-place" and create the "void" now use the cut geometry tool.
Sun, Nov 25, 2012 at 12:04:44 PM | Trouble with creating a Ribbed Groin Vault
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thanks Ty but don't feel you have to follow my posts with your approval. Let's focus on the '0 Replies' posts instead.
Edited on: Sun, Nov 25, 2012 at 1:08:54 PM
Groin Vault Ceiling
Thu, Dec 23, 2010 at 1:40:48 PM
How do I create a Barrel Vault Ceiling
Fri, Apr 26, 2013 at 4:09:23 PM
Barrel vault dormer opening
Thu, Jun 21, 2007 at 2:22:49 PM
Vault
Mon, Jul 2, 2012 at 5:55:12 AM
Custom Ribbed Fascia
Tue, Feb 24, 2009 at 9:27:14 PM
Page generation time: 0.6547
