38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cannot Load Components from Library
Sat, Nov 24, 2012 at 2:26:19 AM | Cannot Load Components from Library
tazman1
tazman1 Avatar
It seems that I can't load a family of components from my library.  When I try, more times than not, I get an error message saying it's wrong name (see attached), which makes no sense.  When I open the file by double clicking it in windows explorer it opens a second session of revit and closes my drawing.  When I try upload into project, it tells there's no open projects to load into.  I don't know if this is related, but I set windows explorer to open .rfa with Revit.  This is very frustrating.
Sat, Nov 24, 2012 at 4:33:24 AM | Cannot Load Components from Library
4 Stars: 201 Votes
That's because you are trying to load a different category of components, if you want to load a "Column" first select select "Column" at your ribbon now select "Load Family"
Sat, Nov 24, 2012 at 11:11:53 AM | Cannot Load Components from Library
tazman1
tazman1 Avatar
Columns was a bad example.  I can't add this window from my library.  Several items in my library tell me I have the wrong name when I try to load them.
Sun, Nov 25, 2012 at 6:55:06 AM | Cannot Load Components from Library
4 Stars: 201 Votes
I don't have any problem with this, maybe the "Path" locations in your options? Try to change the name of that window and see what happens!
Sun, Nov 25, 2012 at 12:16:02 PM | Cannot Load Components from Library
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ok
1. The first thing I noticed is your families do not seem to have the .rfa extension ? Is this a MS Windows setting ? Are they actually .rfa files ? That would explain the error. Look at my picture and Ty's picture. We both show .rfa. Yours does not. Are athey actually .rfa files ??
2. Instead of using any of the 'load family' tools from REVIT just drag the file(s) into REVIT directly from Windows Explorer. Much faster, easier and the family category plays no part.
Sun, Nov 25, 2012 at 10:56:36 PM | Cannot Load Components from Library
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
DGCAD, It is not necessary to be shown the .rfa extensions. Some people can set the 'Hide Extensions from the 'Folder Options'. Moreover if you observe the first image you can see 'Chamfered Column.rfa'.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Sun, Nov 25, 2012 at 10:57:48 PM | Cannot Load Components from Library
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Check the attached image.
Pavan Reddy
Revit Manager
Sun, Nov 25, 2012 at 11:58:25 PM | Cannot Load Components from Library
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thank you, I am well aware of the Windows setting.
So what happened when you dragged the rfa files from windows explorer ?
Wed, Jun 1, 2016 at 6:31:16 AM | Cannot Load Components from Library
Euphii
Tazman1,
I would advise to check the folder path. You may have it set to correct folder until Libraries folder. If you have switched units in a project to other than the folder path, you will get that error and it is a frusturating small detail.
Using US(or whatever country) Imperial, load Imperial families.
Using US Metric, load Metric families.
Cheers
Components Will Not Load Under Any Circumstances!
Sun, Sep 6, 2009 at 1:37:59 PM
Library Components, Metric and Imperial
Mon, Apr 30, 2012 at 12:38:59 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
I can't load anything from my library.
Thu, Jul 25, 2013 at 10:16:10 AM
Furniture as detail components
Wed, Nov 9, 2011 at 5:30:43 PM
Page generation time: 0.5779
