86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Newbie HELP! Can't draw Model Lines in Sections or Elevations anymore.
Sat, Nov 24, 2012 at 1:02:24 AM | Newbie HELP! Can't draw Model Lines in Sections or Elevations anymore.
Memmelle1
1 Stars: 1 Votes
I'm sure there is a simple fix, but since I'm green to Revit, I am clueless.
I'm attempting to draw model lines in section and keep getting this message:
"None of the created elements are visible. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
What am I missing? Everything was working and I'm not sure what changed.
Sat, Nov 24, 2012 at 1:23:37 AM | Newbie HELP! Can't draw Model Lines in Sections or Elevations anymore.
Memmelle1
1 Stars: 1 Votes
I've discovered that now, the model lines I draw end up X number of feet further inside my building. ???
Sat, Nov 24, 2012 at 4:54:06 AM | Newbie HELP! Can't draw Model Lines in Sections or Elevations anymore.
4 Stars: 203 Votes
First select the "Workplane" then draw the model lines in that section view, in plan view create a "ref. plane" near the place you want your model lines, select "set work plane" and select that ref. plane, open that section view and draw the model lines.
Sat, Nov 24, 2012 at 3:24:55 PM | Newbie HELP! Can't draw Model Lines in Sections or Elevations anymore.
Memmelle1
1 Stars: 1 Votes
I get it. So I pick the plane on the plan and then work on the section or elevation. I was trying to select the plane IN the section. Thanks for the clarification. I knew it was going to be something simple. Thanks.
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Displaying a 'call out' tag from a section or plan on Elevations - Possible?
Sat, Jan 20, 2007 at 10:42:49 AM
Section lines
Fri, Aug 18, 2006 at 3:59:38 PM
editing elevations & sections
Thu, Mar 16, 2006 at 4:45:49 PM
Symbolic/Model lines bug!
Wed, Oct 21, 2009 at 1:39:23 AM
Page generation time: 13.2547
