89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> Worksets >> A question..
Wed, Nov 21, 2012 at 3:24:59 PM | A question..
Dozing
I'm curious to know how often people on worksets sync to central.  We are trying to figure out the magic time frame here.
Wed, Nov 21, 2012 at 3:57:12 PM | A question..
Up to you and what you are doing.
  • Sometimes I change things to see the consequences and I may not like them.  Once you sinc, you can't undo.
  • Do you have backup power? - You can wait longer
  • Has someone asked you to release somethig or are you requesting that from someone else?  - you will need to sinc
No magic number... just what makes sense.  I have my reminder set for 15 minutes I think but I ignore that a lot.
Wed, Nov 21, 2012 at 4:53:05 PM | A question..
Dozing
It seems as though when I sync to central my co-workers revit dwg changes unexpectantly.  I'm not talking about the drawing updates, those are good, but rather the parameters of the drawing.  For example his crop lines change to what mine are set at.  This isn't a big deal, but readjusting crop lines every 15 minutes is probably getting old.
Fri, Nov 23, 2012 at 7:44:13 AM | A question..
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you change your crop view extents in a floor plan and sync and then they sync their crop view extents will also change.
"readjusting crop lines every 15 minutes is probably getting old."  Set them to where you both want them and stop changing them
Fri, Nov 23, 2012 at 9:15:40 AM | A question..
Learn to use the power of Revit.
We create working views for modeling, especially plans.  One per individual and named accordingly like Myname First Floor....  In those views you can leave notes for yorself - place critical dimensions and note them as such.  Obviously sheet views should be fixed and only worked in when needing to annotate them.
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:41 AM
Computer Processor Question
Fri, Jul 21, 2006 at 9:49:49 AM
Revit Mechanical Equipment question VAV unit question
Mon, Oct 24, 2016 at 4:17:01 PM
Blue ? ( question mark) shared parameters [ 1 2 ]
Mon, Jan 17, 2011 at 1:17:43 AM
20
Revit 2012 - material tag "question marks" everywhere
Wed, Sep 13, 2017 at 9:26:14 PM
13
Page generation time: 0.6087
