Forums >> Community >> Newbies >> Creating Labels for Family Objects
Wed, Nov 21, 2012 at 7:59:14 AM | Creating Labels for Family Objects
timbarker
I will start out by saying that I am making the transition from Arris to Revit and while some things have been easy to learn there are others that are not quite so easy.
I am working on creating a family for office cubicles and have a couple of questions and wondering if certain things are even possible with Revit.
- I am creating the family using the "Furniture Systems" template. Is this correct template to use?
- I am wanting to add a label that will display the cubicle wall size for each individual wall used. I have attached a sample that shows what I am looking for.  Also wondering if I can make it so that these labels can be turned on or off. Reason for this is that I want the labels visible when editing and looking at the "Level" but not when viewing in 3D.
Wed, Nov 21, 2012 at 9:29:11 AM | Creating Labels for Family Objects
Download the Families Guide from the AutoDesk sit.  It gives you a good working knowledge of how to build families including proper templates - tags - parameters ...etc.
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
Creating Stair- Labels block sketch view- Revit 2016
Thu, Nov 5, 2015 at 4:42:48 PM
Revit 2014 - Controlling distance between Labels in Tag
Wed, Apr 16, 2014 at 1:49:09 PM
Nested Labels Not Showing Up
Fri, Sep 4, 2009 at 7:38:48 AM
Creating objects
Thu, Nov 16, 2006 at 6:06:59 PM
Page generation time: 19.9367
