Forums >> Revit Systems >> Technical Support >> Load Calcs not using CFM/SF?
Mon, Nov 19, 2012 at 12:41:59 PM | Load Calcs not using CFM/SF?
Gyvven
5 Stars: 2 Votes
It's been quite a while since I've used Revit to run any sort of load calc, but I've been asked to look into it again. So, I whipped up a quick little model consisting of 2 open office areas, 2 private offices and a restroom, each with a plenum. Each space was assigned it's own zone (including the plenum) and everything was defined for each zone and space. Outdoor Air was defined as .085 CFM/SF (.06 + .025 per person) to fudge 62.1 figures.
When I run the calculations it returns 0 Ventilation Load if I only have the CFM/SF checked. If I check Per Person and define it as 5 CFM I get a return of 4 CFM per person (.02 CFM/SF) in my Loads Report, which is at least returning a value even though it's wrong. Air Chnages per Hour also seems to work, though I haven't really dug into those numbers very closely.
Why won't CFM/SF return a value in my Load Reports? I'm sure it's something simple I'm missing, but I don't understand why the other two options work.
I started this in 2012 and migrated up to 2013 to see if that would fix anything. It didn't. I recall I had gotten decent results in 2010 using the CFM/SF but can't seem to replicate it in '12 or '13. I'll keep playing around with it, but if anyone has some insight I'd appreciate it.
Tue, Nov 20, 2012 at 11:07:27 AM | Load Calcs not using CFM/SF?
Gyvven
5 Stars: 2 Votes
I don't know what the issue was, but I re-started the project from scratch and the CFM/SF started working. I'd like to figure out what the issue was in case it happens on a larger project that can be quickly redrawn.
Cooling Load Calcs
Thu, May 1, 2008 at 10:23:54 AM
Calculating CFM on Return Ductwork problem
Mon, Dec 1, 2008 at 1:43:37 PM
Will a change in cfm update ductsize?
Mon, Mar 14, 2011 at 7:58:47 AM
Load Calcs for LEED
Thu, Apr 17, 2008 at 3:41:03 PM
Egresss Calcs
Thu, Jan 25, 2007 at 10:30:56 AM
Page generation time: 0.4345
