50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Fascia Board Too Long
Mon, Nov 19, 2012 at 10:46:06 AM | Fascia Board Too Long
thedboys95
5 Stars: 2 Votes
On my shed I extruded a barn style roof and changed the cut to a Two-Cut Square. When I add a fascia board to the extruded sides of the roof the cut on the fascia board is a plumb cut. How do I change/trim the board so it matches the width and cut of the roof?
Mon, Nov 19, 2012 at 12:52:47 PM | Fascia Board Too Long
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you place the fascia board in sequence around the roof, it should create the correct cuts, if you skip around it does not remember what the previous cut was or rather, it uses the previous cuts, to create the next.
Tue, Nov 20, 2012 at 10:19:32 AM | Fascia Board Too Long
thedboys95
5 Stars: 2 Votes
The barn is 12x16, extruded so that I drew the roof along the 12 side. When I place the fascia board along the 16 side, it is placed perpendicular to the roof for some reason since the roof has a square cut. Along the 12 side the fascia board extends too long and the triangular plumb cut of the board extends past my roof. I can't get my file to post when I attach it so I am trying my best to describe it.
3D Fascia Board Help
Thu, Jun 11, 2015 at 8:47:42 AM
Can't get fascia heights to match
Thu, May 19, 2011 at 4:57:16 PM
Custom barge board/ fascia end profile
Mon, Oct 15, 2012 at 3:14:43 PM
12
fascia on two different sloped roofs
Thu, May 28, 2009 at 1:01:05 PM
Cut Fascia by roof
Mon, Jun 25, 2012 at 10:39:50 AM
Page generation time: 0.7186
