55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door and Window Scheduling - showing the door and window as an image.
Sun, Nov 18, 2012 at 10:58:18 PM | Door and Window Scheduling - showing the door and window as an image.
billz1508work
Hi, i have started my first alone documentation project. I am using REVIT and soley Revit for this project. I have been using REVIT for a while but only for school projects. I need some help with door and window scheduling. I am required to show a schedule which also shows the images of the doors. Is this possible in revit. I have added, "model" to the schedule fields, I assumed this would add an image of the door, however nothing shows up in this field. Is this possible in REVIT if so how, if not, is there a work around?Regards Bill
Sun, Nov 18, 2012 at 11:48:38 PM | Door and Window Scheduling - showing the door and window as an image.
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
I am not clear with your question, hope this helps...Using Legend Component in Legend and place on the sheet beside your schedule or directly import image on to the sheet.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Mon, Nov 19, 2012 at 3:32:22 PM | Door and Window Scheduling - showing the door and window as an image.
billz1508work
Hi Pavan. Atm the schedule only shows the details of the door. e.g. height, sill height frame width etc. I actually need to add an image/diagram to the schedule of each door..Similar to what you would see a door in elevation, though 20 doors on one sheet, where i can annotate and dimension. Just wondering if REVIT did this automatically, or if i have to create a view of each door in elevation and then put them all on a sheet and annotate them individually. I would imagine well hoped there would be an option where REVIT could put an elevation view of each door as part of the schedule.Sorry for not being clear.
Mon, Nov 19, 2012 at 4:03:59 PM | Door and Window Scheduling - showing the door and window as an image.
I think you need to use the legend component and see what you have.
Mon, Nov 19, 2012 at 4:50:10 PM | Door and Window Scheduling - showing the door and window as an image.
Sofus
1 Stars: 1 Votes
The company I work for has developed a tool to set up legends with a layout template, so Legend components are included in a automaticly generated element-type-legend. Our homepage is in danish (nti.dk), its a scandinavian Autodesk reseller, but the tool is in english. I can help if you are interested, or maybe someone has developed something similar in Autodesk exchange.
Sofus
Mon, Nov 19, 2012 at 11:57:11 PM | Door and Window Scheduling - showing the door and window as an image.
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Bill, Create a Legend view then using Legend component you can place doors and windows. Try this.
Pavan Reddy
Revit Manager
Wed, Nov 21, 2012 at 5:23:24 PM | Door and Window Scheduling - showing the door and window as an image.
billz1508work
Thankyou all, legend components worked like a treat. Thanks
Thu, Feb 11, 2016 at 12:17:43 AM | Door and Window Scheduling -
farispilakattil
hi, i need door schedule on sheet in only vissible view ( only first floor not in all schedule) anybody know...let me share...
Thu, Feb 11, 2016 at 7:50:52 AM | Door and Window Scheduling - showing the door and window as an image.
Add fllor level to your schedule and use that to filter it.   You can hide that column if you want.
Need help tagging/scheduling a door with a sidelite
Tue, Jun 8, 2010 at 2:15:23 AM
Door and Window types
Thu, Nov 23, 2017 at 11:19:53 AM
Door / Window Tag
Tue, Mar 4, 2008 at 1:01:45 PM
Creating Window or Door Legends
Wed, May 3, 2006 at 10:30:17 AM
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:51 PM
Page generation time: 0.8608
