Forums >> Revit Building >> Technical Support >> Show Hidden Line - Not working the way I want it to
5 Posts No Rating |
I'm having an issue with "Show hidden view" in Revit Architecture 2013.In my basement reflected ceiling plan I want to show the outline of structure beyond.The concrete beams are shown correct (hidden lines) but the W-Wide Flange beams are shown as a continuous line.I reset the element override. I checked the object styles (all hidden lines settings are set to dashed)but the wide flange beam still shows as a continuous line.Am I overlooking something?Is there a setting in the wide flange beam family that I should change?Any advice or input would be greatly be appriciated.Thank you very much!
Try to "Override Graphics in View" by "category"
oops.. this one too
I don't have any problem with both the beams. Check the attached image.
What is the length of your W-Wide Flange beams, may be scale problem.
Post some images for more clarity.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
5 Posts No Rating |
I found the reason why it wasnt showing the way I wanted to! Someone working on the project set a plan region (that cuts right through the beam) around the area I'm working on and turned the visibility off. Doh!
So i turned plan region setting on and adjusted the view range within the plan region and BOOM... I got hidden lines showing.
thanks for your input guys!
Cheers.
Hidden Line Tool not working through links. |
Tue, Jul 20, 2010 at 9:06:09 AM
Show Hidden Lines - Structural Foundations |
Thu, Jan 13, 2011 at 10:37:02 AM
hidden lines not working on linked model |
Mon, Jan 13, 2014 at 5:00:37 AM
Line Styles Adjusting with Wall Hidden Lines? |
Mon, Mar 12, 2018 at 12:58:30 PM
Show Hidden Line. |
Thu, Jun 17, 2010 at 5:39:46 PM
Members: | 2102364 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
