18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit liscense
Thu, Jan 19, 2006 at 8:33:33 AM | Revit liscense
wkarabinos
The company i work for has a couple of revit liscenses. I was under the impression that you can install the software on your home computer as long as it is being used by the same person at the two computers. I installed the software at home but im not sure as to what i put in for the serial number. The serial number i have on the software at work i put on the software i have at home and apparently it didnt work cause i want to use the program at home and its telling me that the liscense is expired and it will only let me work in demo mode. Can someone please help me out with this problem. I need to know what serial number im supposed to use for it to work properly.
Thu, Jan 19, 2006 at 12:32:10 PM | RE: Revit liscense
josta
1 Stars: 1 Votes
Your impression is correct; I have done the same thing. The license you input should have worked fine, unless it was a student version as normal Revit licenses are perpetual. I suggest you email Autodesk with this question.
Thu, Jan 19, 2006 at 4:48:19 PM | RE: Revit liscense
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can use the portable licence utility available from autodesk to use your licence from the office at home when needed then move it back.
Thu, Jan 19, 2006 at 5:09:13 PM | RE: Revit liscense
wkarabinos
Can you use the portable liscense utility work with revit. i know how to fo it with autocad but im not sure about how it works with revit
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 17.8067
