49 Users Online (47 Members):
Forums >> Revit Structure >> Tips & Tricks >> steel beams and columns
![5 Stars: 2 Votes](/images/stars_5.gif) |
hi,
i am using revit structure 2011 and i have been working around with a representation issue.
as you can see on the attached image the beam doesnt completely joins automatically with the column, and i have to do it manually.
on the picture this happens only with the vertical beam but not with the one horizontally
i have been working around with the settings and nothing. i would really apreciate the help
thanks in advance
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
1. Always make sure when you model the beams that you snap to the center / middle of the column and let the geometry do what it does.
2. Look up 'cutback' and what it does.
3. As per the attached image, every column has an imaginary box that goes around it. Then when beams and braces come into play the beam's Instance parameter for Start Extension and End Expension determine how to trim back the beam. In my case it is '-1/2". A positive Extension will push the beam into the box. A negative pullsl the beam away from the box.
If you clcik the a beam in this case, you can also control the Extensions with the triangular grips. Note that if you do so it will change the instance properties of the beam.
Hope this helps.
Edited on: Sun, Nov 25, 2012 at 1:00:27 PM
hidden steel columns showing as solid |
Tue, Nov 23, 2010 at 12:18:43 PM
turn beam system into columns |
Tue, Oct 26, 2010 at 11:08:49 AM
Advice on beam casing |
Fri, Oct 14, 2011 at 2:45:48 AM
Can't select beams nor columns |
Sun, Mar 10, 2019 at 10:12:36 PM
BEAMS JOINING COLUMNS problem |
Tue, Jun 30, 2015 at 7:41:51 AM
Members: | 2017506 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
