66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Dimensioning Concentric Circles...? Revit Arch 2012
97 Posts No Rating |
Is there a way to do a continuous string of dimensions of concentric circles? I have a project with a long radiused wall with multiple materials and I want to do a string of dimensions from exterior face to exterior face and I can't figure out how to run the radius dimension continuously from one to another. It seems to only want to dimensio from center of the radius to one face, not allowing me to dimensio to the next face.
Am I missing something?
If I understand your question right you can add a reference line to where you want to start dimensioning from then revit will let you pick the walls from face to face. If I'm missing your point please add a picture to explain further what you are trying to accomplish
Teafoe, thanks but not what I meant. From your image, I'm looking for a string of dimensions from the Centerpoint to each part all the way to the exterior most layer.
Draw a line alog what you want to dimension - from the center all the way out. That will give you intersections to dimension to. If you don't like the line, break it up so you just have small pieces crossing your circles.
Is this what you meam?
How do you create a concentric spiral? |
Fri, Jan 6, 2012 at 10:29:39 AM
Revit Arch. 2012 30 day trails??? [ 1 2 ] |
Wed, Jan 2, 2013 at 12:30:37 PM
18
Links not showing families of Arch file. |
Wed, Jun 20, 2012 at 3:16:42 PM
Crop Circles...? |
Thu, Dec 1, 2011 at 5:48:31 PM
Most Bizarre Revit Problem EVER |
Thu, Jan 22, 2009 at 11:43:49 AM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
