58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> painting split walls with windows
Thu, Nov 15, 2012 at 12:46:02 PM | painting split walls with windows
lagb
I have a wall with windows & a multiply split face surface. When a paint material is applied across the region where the
windows are, the windows are no longer transparent & the paint material in this region is now within the glass area of the
windows. PLatform is Revit Structure 2011.
Because of the multiple splits, I believe that the split face is the way to go here...
All insight appreciatted.
LAB
Thu, Nov 15, 2012 at 3:17:04 PM | painting split walls with windows
Only material faces get painted when you do this..... So you have something else happening.  I don't believe the split is misbehaving.
We sometimes use thin objects.  Like for tile floors - walls.  Then they can be manipulated easier than split faces.
Split Facing and Painting both sides of a wall?
Fri, Jan 13, 2017 at 10:52:50 PM
Painting Single Walls
Wed, Oct 17, 2007 at 9:10:34 AM
Exterior Windows elevation
Sun, Aug 26, 2012 at 5:26:57 AM
12
painting walls
Mon, Feb 20, 2012 at 9:35:25 PM
painting walls
Tue, Jul 5, 2011 at 6:29:48 AM
Page generation time: 1.0719
