42 Users Online (41 Members):
Forums >> Revit Structure >> Technical Support >> Placing Weather Vane On Roof
![5 Stars: 2 Votes](/images/stars_5.gif) |
I'm currently making a barn, and no barn is complete without a weather vane on top. However, I cannot seem to place it on the very top edge of my roof. Im not sure how to go about doing this because the top edge isn't a true work plane. Im very new to revit and thank you in advance.
Edited on: Thu, Nov 15, 2012 at 10:32:52 AM
Did you make the weather vane? Does it need to be hosted to a face or a plane? You can create a reference plane at the point where you want the weather vane to go and host it to that plane. Photos are always helpful along with as much helpful information as possible.
Hello KposK17. I am very new to Revit as well and I had a similar problem placing items on my roof as well but I found that you have to make sure you work in the ceiling plan level 3 and create a third elevation at the very top of the roof in order to work in the top plane. But I could be wrong
go to elevation then make a new elevation at the level you want
i did not make the weather vane, just downloaded it yesterday. still not sure how to explain this but i'll attach a file of my project.
If it is a work plane based family, simply add a new reference plane and set it.
Edited on: Thu, Nov 15, 2012 at 10:49:18 AM
ok thanks. and how do i go about making a reference plane? Im still very new to this
Go to an elevation or section view ... home tab ... pick ref plane and draw it... Very hard to do.
*New to Revit* - How to 3D model weather barriers? |
Wed, Oct 8, 2014 at 1:43:41 PM
Weather Ledge, Drip Ledge, Sheeting notches? HELP! |
Fri, Apr 4, 2008 at 11:46:41 AM
Weather Rated GFI outlet |
Wed, Oct 6, 2010 at 11:12:11 AM
Serious problems with roof |
Wed, Nov 24, 2010 at 2:54:46 AM
14
placing beams |
Fri, Jan 8, 2016 at 5:29:09 PM
Members: | 2019203 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
