52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Material not showing up in family
Thu, Nov 15, 2012 at 1:55:55 AM | Material not showing up in family
kvinso1
I am trying to apply a plaster material to an extrusion in my family and it's working on the bottom half but not on the top half.  It appears the material is "fighting" with something else because it peeks out and I can see it "sort of" when I orbit.  Any suggestions on how to fix this or know why it's happening?
Thu, Nov 15, 2012 at 2:06:30 AM | Material not showing up in family
kvinso1
Sorry first time posting, I'm using Revit Architecture 2013
Thu, Nov 15, 2012 at 3:57:23 AM | Material not showing up in family
4 Stars: 203 Votes
"...and it's working on the bottom half but not on the top half. " - Is that ONE object or TWO obj.?
Thu, Nov 15, 2012 at 8:09:52 AM | Material not showing up in family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Don't paint the extrusions add an actual MATERIAL to them.
Thu, Nov 15, 2012 at 11:00:44 AM | Material not showing up in family
kvinso1
They are two separate extrusions.  I tried adding a material as suggested in the second post but that doesn't seem to be working either.
Thu, Nov 15, 2012 at 11:19:32 AM | Material not showing up in family
I believe this is a process error.  Because the project rules (it over-rides any same named material changes to the family), and in order to understan how all this works, suggest you do the following:
  1. Open the family for editing.
  2. Pick each individualle modeled element in the family, one at a time, and in its properties, assign a new, uniqually named material that is unlike anything in your project.
  3. Now - before loading this family, save it with a new name - then load it.
  4. In your project, pick the old family and swap it to the new.
Learn from this....
Thu, Nov 15, 2012 at 11:21:06 AM | Material not showing up in family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You have 2 extrusions on top of one another, erase one and the material will work.  Also you have a LOT  of painted items.  Make sure you use the REMOVE PAINT tool and remove ALL the paint.
Edited on: Thu, Nov 15, 2012 at 11:22:45 AM
material not showing in render.....plz help
Sat, Jul 2, 2011 at 5:44:28 AM
material not showing up in project from family editor
Thu, Apr 15, 2010 at 4:19:25 AM
Object Material Not Showing
Wed, Dec 9, 2015 at 9:05:16 AM
Lines showing through material
Mon, Apr 2, 2018 at 11:14:55 AM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:36 PM
Page generation time: 1.0017
