Forums >> Revit Building >> Technical Support >> swept blend with more than 2 profiles
12 Posts No Rating |
Hi,
I am trying to do a swept blend with 4 profiles and I tried to follow the revit 2013 help. the guide tells me to create the path which i have done and than add point elements. I can't find these "point elements" in my "draw" panel. I attach a sceenshot of my problem and I am sure there is an easy solution to that.
Thanks in advance
Martin
Swept Blend = ONLY 2 Profiles
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2760-Tools_an2760/2761-Sketchin2761/2785-Creating2785/2797-Creating2797
Thanks Typhoon,
in the wikihelp there is an option for 2 and more profiles, please see attached link. that's what I am tring to do.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0135-Prelimin135/0204-Conceptu204/0256-Forms256/0265-Form_Typ265/0270-Swept_Bl270
Martin
It is possible, but you are using the wrong tools or environment. The sample in Wikihelp refers to a family that uses the options that are available in the generic adaptive template, the mass template, or the in-place mass tool. By your illustration, it seems that you started with the in-place component tool, which does not have the reference points option.
Edited on: Thu, Nov 15, 2012 at 11:52:09 PM
Planta1 Revit Online Consulting | info@planta1.com |
Thanks alfmedina,
that was the problem. It just makes no sense to me why I can't use it in the in-place component tool.
Martin
Swept Blend |
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!! |
Mon, Jul 28, 2014 at 3:31:14 PM
cannot rotate the reference plane of a swept blend |
Tue, Feb 23, 2010 at 6:22:35 AM
how to do a tubolar spiral? |
Mon, Jun 18, 2012 at 1:07:34 PM
in-place coil spring |
Wed, Apr 27, 2011 at 8:52:31 PM
Members: | 2115632 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
