38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Sloping ceiling Revit 2012
160 Posts No Rating |
I have the underside of a stair cutting through a room. I have created a ceiling in the room but cannot seem to be able to create a sloping section of ceiling to suit the underside of the stair. I have attached 2 dwgs to describe my situation.
I want to do a layout for the lighting in the ceiling plan but do not want it to show in the floor plan
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Create a "In-place" family in "Ceiling" category.
Does the 'Slope Arrow' in the Ceiling skecth mode work?
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
I can't get it to line up with the angle of the u/s of the stairs!!
Cheers Dermot
www.dmbd.net |
Try specifying heights at head and tail of slope arrow.
Pavan Reddy
Revit Manager
Specifying the base height of the ceiling and the offset height at the head of the slope arrow should be enough to make the sloped portion. The length should match the length of the flight of the stair. Then do the flat portion as a separate ceiling.
Planta1 Revit Online Consulting | info@planta1.com |
ceiling based component in sloping ceiling 2010 |
Tue, Nov 6, 2012 at 4:41:27 AM
Sloping Ceiling |
Mon, May 25, 2009 at 2:35:31 AM
REVIT 2013 Sloping Pipe System Tutorial |
Wed, Jan 2, 2013 at 9:37:26 AM
Removed Banked angle from sloping Pads |
Tue, Nov 3, 2015 at 4:17:31 AM
Sloping semi circular roof Revit 2012 |
Fri, Jul 19, 2013 at 12:49:30 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
