160 Users Online (159 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked Door Schedules
Wed, Nov 14, 2012 at 3:38:47 PM | Linked Door Schedules
jengland
Revit Arch 2012.  I have become involved with a Revit project that links several Central Revit models.  One door schedule in the composite Revit file contains a field that is not listed in the linked central file door schedule.  Other linked files are reloading with identical schedule fields.  Any ideas?  If I did not make myself clear...the basic jist is a schedule field exists in the composite file (contains several models) but it does not exist in the central file that is linked into the composite file.
Edited on: Wed, Nov 14, 2012 at 3:48:00 PM
Thu, Nov 15, 2012 at 7:13:27 AM | Linked Door Schedules
So it isn't in that file.... If you need it there, then add it!
Linked file element parameters have to exist in the linked file in order to be scheduled.
Linked Revit Door Schedules not showing any data Revit 2015
Mon, Aug 3, 2015 at 12:07:23 PM
Linked door schedules issue
Fri, Apr 3, 2009 at 1:13:49 PM
Schedules: Ie Door schedules!
Fri, Jul 11, 2014 at 2:58:23 PM
Linked Door Schedule Problems
Fri, Jul 4, 2008 at 3:37:39 AM
Best Practice - Door details in linked files.
Fri, Mar 20, 2015 at 7:50:47 AM
Page generation time: 0.8488
