35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Foundation plan/level view (R2013)
Wed, Nov 14, 2012 at 10:07:31 AM | Foundation plan/level view (R2013)
OlavM
It should be very easy, but I just can't figure out how to view only foundation plan/view.. Problem is, that I made foundations hosted by walls and now I can only see them in "structural plan - level 1" within the walls, but I would like to see only footings, not with walls.. Shouldn't there be a special "foundation level" or smth in the views panel? Any help is welcome!
Thanks
Wed, Nov 14, 2012 at 11:00:31 AM | Foundation plan/level view (R2013)
If you have a level called foundation then from your view tab, create a plan of that level.  If you don't, then you can create the level and then make the plan.  Set your view range accordingly.
Also, you can copy the floor plan, change the view range, call it a foundation plan and turn foundations on, walls off.
Wed, Nov 14, 2012 at 12:14:20 PM | Foundation plan/level view (R2013)
OlavM
How do I just copy the floor plan? Like I said, I have only structural plan level 1 where the footing with walls can be seen. I would like to create foundation plan without walls. The question is how?
Wed, Nov 14, 2012 at 12:19:32 PM | Foundation plan/level view (R2013)
Fundamentals....
View tab -  / plan views / floor plans / uncheck the do not duplicate box and pick your level.  Set your view range and VG settings.
Foundation Plan Help
Sun, Feb 28, 2010 at 9:00:28 AM
Level 1 room boundries showing up in foundation level
Fri, Feb 15, 2008 at 9:31:37 AM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:02 AM
Foundation plan view depths
Sat, Jun 17, 2023 at 1:34:15 PM
Plan view levels
Tue, May 5, 2009 at 3:15:04 PM
Page generation time: 1.0246
