54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> curved curtain wall
Tue, Nov 13, 2012 at 11:29:33 AM | curved curtain wall
4ABs
Hi all,
I have been working with revit sice 2007. I'm using revit 2013 and I'm trying to do a curver curtain wall but when I draw the wall  even if a pick curved style revit draw the wall straight.
But whe a draw a exterior or inerior wall cmu or partition it does it curved, but when I change any to curtain wall this change to straight.
Thanks,
AB
Tue, Nov 13, 2012 at 11:32:50 AM | curved curtain wall
I can't ever recall seeing a truely "Curved" curtain wall.  That's because glass is best done flat - unless you have oil money in the project.
Add enough CW grid's to approximate a curve.  The spacing should probably not be less than 2-3 feet.
Edited on: Tue, Nov 13, 2012 at 11:34:13 AM
Tue, Nov 13, 2012 at 11:47:05 AM | curved curtain wall
4ABs
Got it!!!
I figure it out........
Thanks
Tue, Nov 13, 2012 at 6:54:33 PM | curved curtain wall
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Revit already should been doing that anyway!
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Wed, Nov 14, 2012 at 8:41:38 AM | curved curtain wall
Not true Carru.  We often use a curtain wall type that has no pre-set mullion spacings.  That type would come in as a straight CW from curve endpoint to endpoint.
Wed, Nov 14, 2012 at 9:55:56 PM | curved curtain wall
JohnCubed
A good start might to take a Generic 6" Wall>Edit Type>Edit Structure>Change Material to Glass>Change Thickness to 1">OK Ok ok. Now you have a glass wall type that you can curve to your heart's content. Attached is a picture of the Sick Kids Foundation under construction here in Toronto showing some nice use of curved glass.
Sun, May 12, 2013 at 1:54:02 PM | curved curtain wall
curryhp
i had met the same problem just now, but finally i can do curve wall after shut down and restart revit2013
curved angled curtain walling
Wed, Mar 8, 2006 at 4:18:51 AM
curved curtain wall, straight transoms, curved panels
Tue, May 12, 2015 at 8:36:04 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:48 PM
curtain walls
Sun, Dec 7, 2014 at 9:29:55 PM
Curved Curtain Wall
Sun, Aug 29, 2010 at 6:11:24 AM
Page generation time: 2.0497
