32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> hide sections of section lines in plan
Mon, Nov 12, 2012 at 7:25:37 AM | hide sections of section lines in plan
burtont
I am using revit 2012 and have several section views in my project and they have jogs in them. Is there a way that I can hide those jogs? Right now I have the usual section line breaks in place, but where the section jogs there is still a funny looking corner in the middle of my plan. Any suggestions? and the masking region I am using is not working...
Mon, Nov 12, 2012 at 7:53:03 AM | hide sections of section lines in plan
I don't believe you can remove the jog.  I have alwyas kept it long enough so that you would know what it is.  If you don't like that, then don't do a building sction.  Use two sections.
Mon, Nov 12, 2012 at 8:16:51 AM | hide sections of section lines in plan
burtont
yeah i had explored using 2 sections (similar to an angled section cut from orthagonal) but that is too much of a hassle for this. I ended up just shrinking the jogs down so all you see on screen is a small dot which I can live with
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
Sections Referencing the drawing you want. Help Cheat!
Fri, Feb 25, 2011 at 11:22:05 AM
Section Lines not showing up on a plan
Thu, Jan 8, 2009 at 9:32:28 AM
Hide sections in all project except in a plan view
Sat, Feb 4, 2012 at 9:46:23 AM
Create Section lines to place sections separately under project browser
Mon, Sep 10, 2007 at 8:15:49 PM
Page generation time: 13.2165
