107 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> SIPS Walls and Roofs
3 Posts No Rating |
I want to model a house using SIP (Structural Insulation Panels). Creating the wall is easy but I want to show the separate panels as they come in standard sizes of 1200mm wide. I want a line at 1200mm intervals that will depict the join of a panel - it will make it that much easier to model. I tried using a hatch pattern but I can't get it to work. Any ideas how I do this?
Thanks
Create a "Hatch" for that...
3 Posts No Rating |
Thanks - such a simple solution - I should have worked this out myself!!! Sometimes you can't see the wood for the trees ... ha ha
Attaching curtain walls to multiple roofs |
Mon, Nov 5, 2012 at 2:19:44 PM
I can't work out how to incorporate a wall I downloaded from NBS into my project |
Tue, Jun 13, 2017 at 12:58:45 PM
Join 2 roofs, like joining 2 walls |
Wed, Nov 10, 2010 at 7:23:34 AM
How do you convert massings into floors, walls and roofs?? |
Thu, Jul 16, 2009 at 4:48:55 PM
Cut hole for window in timber cladding? |
Fri, Mar 18, 2016 at 7:46:53 AM
Members: | | Objects: | | Forum Posts: | | Job Listings: | |
