78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit Architecture 2012 - Copy/Mirror Changes Component levels
Thu, Nov 8, 2012 at 3:10:37 PM | Revit Architecture 2012 - Copy/Mirror Changes Component levels
Ripcurl2280
I have this terrible issue with my project that has to do with copying and mirroring.
Quick background...
Back when this project was started, it was started by someone who didn't know much about Revit. There is an existing building with it's own levels and new levels were created for the new construction. The 3rd, 4th, & 5th floors (existing and new) all have the same elevation from existing to new.
My problem is that when I'm in the new construction plans/views (with the correct associated levels) and I try to copy and/or mirror something, the new component created from the copy/mirror switches itself from the correct level that I'm using (the new construction) to the existing level that means nothing.
Example: If I am on the 5th floor new construction plan and copy a chair that is associated correctly with 5th Floor New Construction (level name), the chair that is the copy is now associated with the level that is 5th Floor Existing (level name).
Why would it do this? What would make the program default a copy of something to the level that isn't even associated with the views that I'm working in?
I'm already aware that levels cannot be merged. I've tried so many work arounds to this but it seems unsolvable.
Any help/advice would be great, or I'm going to lose my marbles. It's extremely tedious and annoying to constantly have to pay attention to something so ridiculous like this on a job that has such a large scope.
Thu, Nov 8, 2012 at 3:55:56 PM | Revit Architecture 2012 - Copy/Mirror Changes Component levels
3.5 Stars: 401 Votes
Views have nothing to do with this.  The level name must be unique if it is not the same level.
Are you copy / mirroring from an existing level.  If so then that is what is wrong.  You would need to copy to clipboard and paste to the new level.
Wed, Feb 6, 2013 at 2:01:45 PM | Revit Architecture 2012 - Copy/Mirror Changes Component levels
SuchitaTS
Or you could just select the object --> go to propeties and change the level of object from there (from 5th floor to 1st)..
See if this could help..
Edited on: Wed, Feb 6, 2013 at 2:05:03 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Mirror Project - Revit Architecture 2013
Sat, Jan 25, 2014 at 5:41:31 AM
how to mirror a family
Wed, May 26, 2010 at 4:09:25 PM
Errors when Copy/Monitoring Levels
Tue, Jan 30, 2018 at 4:27:02 PM
Mirror reflection always looks too distorted in renderings
Tue, Jan 27, 2009 at 4:15:43 PM
Page generation time: 1.7882
