56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Room Numbers in Schedules
Wed, Jan 18, 2006 at 8:38:20 AM | Room Numbers in Schedules
cchollet
Hello, i need help on how to add the room numbers in the schedules, i don't understand the parameters to add the field and link it to the room tag to show on the schedule (if that's how you do it..) Can somebody help me with this please. Thanks a lot...
Wed, Jan 18, 2006 at 11:08:00 AM | RE: Room Numbers in Schedules
TomDorner
4.5 Stars: 25 Votes
It all depends on what type of schedule you are trying to produce. Can you give us more detail? Tom
Wed, Jan 18, 2006 at 12:39:12 PM | RE: Room Numbers in Schedules
quiller
quiller Avatar
2.5 Stars: 3 Votes
If you used the room tag strainght out of the box, and you creted a schedule showing the room numbers/names/etc. Then all you have to do is change the number right in the schedule. You can't add numbers, if the room does not exist.
Wed, Jan 18, 2006 at 3:13:48 PM | RE:
melissa
Thanks a lot...
First when you begin a new schedule, make sure you select "rooms". Then in the filed tab, add the fields " name" and "number" along with any other fields you need such as occupancy load, finishes, etc. You can get to this by right clicking on the schedule name or view and looking at its properties. Also make sure the correct phase in on in the filter tab or you won't see your rooms. You must have room tags placed in the floor plan on the corresponding phase for anything to appear in the room schedule. They are inherently linked and will generate in teh schedule automatically.
Post edited on 2006-01-18 15:15:22
Wed, Jan 18, 2006 at 3:14:24 PM | RE: Room Numbers in Schedules
melissa
Wed, Jan 25, 2006 at 3:26:56 PM | RE: Room Numbers in Schedules
cchollet
Thanks for your help, it was there all along but i did not look that much hu ???...thanks.
Schedule will not tracj all room names and numbers [ 1 2 ]
Fri, Jul 30, 2010 at 5:15:35 PM
16
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Room Tag Numbers
Tue, Jul 8, 2014 at 7:22:54 AM
11
Phasing
Thu, Jul 30, 2009 at 8:01:36 AM
Electrical Panel Schedules - Space numbers
Wed, Sep 3, 2014 at 2:49:40 PM
Page generation time: 0.5897
