88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Spot Levels not working on Plans
7 Posts No Rating |
Hello,
I have a project that I have linked in floor plans. I Cannot put spot levels on the slab Faces?
I have a simular Project again with Links and I have no problem putting spot levels on the slab Faces.
I have checked that the slabs are turned on in the views and I can put Spot levels on in 3D views and in Section Views, but not plans.
I have also linked in the plans that are not working in this file into the file where I have no problems and I can Spot level the slabs there.
Is there a setting somewhare causing this issue? I am stumped.
I am using 2013
![Pavan Avatar](user_avatar/6213.jpg)
![4.5 Stars: 3 Votes](/images/stars_4.5.gif) |
Check if the view is in 'Wireframe' mode.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
7 Posts No Rating |
No it is not in Wireframe mode. This one had stumped me. Hope you can help further. We do not want to mannually put these in.
7 Posts No Rating |
We can also put spot elevations on caseworks, toilets and the like, but the one thing we need (Slabs) not working?
Make sure the floor is really there in the link and that it is on in this view. Linked file VG can be controlled separately from host model so be sure.
7 Posts No Rating |
Yes the Floors are on. I can find the edge of the slabs but not the face.
OK - someone else has to verify this in 2013 to see if it is a bug. This works for me in my current 2012 project.
BTW - You do have the latest build of 2013 - Update release 2. If not then that is probably your problem.
7 Posts No Rating |
I have build: 20120221_2030(x64)
As I stated earlier it is working fine in other files. I am assuming that there is a bug or a setting in this file that is not happy.
If it doesn't say update release 2, then you don't have the latest updates! Install that because it corrected a lot of problems.
Spot Levels [ 1 2 ] |
Wed, Nov 7, 2012 at 10:49:19 PM
18
Spot elevations text on angle |
Thu, Oct 18, 2012 at 9:08:09 AM
Spot levels on external floor family |
Fri, Aug 17, 2007 at 2:44:13 AM
Problem with Levels and Plans |
Thu, Sep 6, 2012 at 12:25:55 PM
Floor tag - elevation spot |
Thu, Apr 27, 2017 at 7:20:09 AM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
