99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> levels - phasing
15 Posts No Rating |
Revit arch 2013
I am working on a renovation and a vertical addition to a 4 story building. I've created the base existing building drawings and started to add new apt unit plans, but am running into a problem with levels and phasing.
the roof is above the fourth floor and will have to be removed (work shown as demo drawings obviously). is there a way in the demo drawings i can show the roof level/roof being removed and in the new drawings have a 5th floor level, then roof deck/penthouse/etc above without them showing up on the demo drawings?
I'm trying to avoid putting levels on top of one another and having to "hide" them when needed. i didnt notice being able to attach a phase to levels, so any advice on best practices for this would be appreciated.
Thanks - Joe
Levels and Grids are not phase specific. I wonder if you could use design options to encorporate what you are trying to accomplish.
any other opinions? Im not sure how feasable a design option would be, or even how to tackle the issue that way.
Levels can be on seperate worksets so that issue can be solved. Obviously, the model elements can be phse controlled.
thanks hub ill look more into that
1 Posts No Rating |
If u are talking about levels I'm assumeing your drawing a section or elevation. Why don't u just hide the level you don't want
to see in a specific drawing?
the more i think about it, that may be the easiest option.
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
model lines blocked by model components |
Fri, Mar 19, 2010 at 3:26:02 PM
phasing |
Tue, Oct 23, 2012 at 8:20:21 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
Wall and Instance phasing warning - Incorrectly Reporting? |
Thu, Oct 11, 2018 at 3:37:00 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
