84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Coloring an area, without coloring my furniture?
Wed, Nov 7, 2012 at 4:13:34 AM | Coloring an area, without coloring my furniture?
petitmaire
Hi everyone.
I'm fairly new at revit, and i stumpled upon a little problem. When i color a floor as an area, only the walls and a selected amount of furniture turn white. how can i secure that all furniture are white in plan?
Regards
Petitmaire
p.s
i attached a file showing where the problem is
Wed, Nov 7, 2012 at 4:56:19 AM | Coloring an area, without coloring my furniture?
gebber
gebber Avatar
5 Stars: 4 Votes
The "white tables" probably have a masking region in the family.
Wed, Nov 7, 2012 at 7:40:31 AM | Coloring an area, without coloring my furniture?
petitmaire
I think you are right about that. The problem is still that when i edit the family to put i region mask on it, it still turnsout "invisble" in my plan view. I hope you can help with my problem, or refer me to a place where i can find out more about it?
thanks
Wed, Nov 7, 2012 at 7:45:40 AM | Coloring an area, without coloring my furniture?
The family is too low.  Raise it off the floor slightly and see what happens.
Wed, Nov 7, 2012 at 8:04:22 AM | Coloring an area, without coloring my furniture?
petitmaire
I tried to raise it and still nothing happened.. I can make a region on a single table and that works, but i ofc want to add it to the family.. damnit im getting annoyed Puh
Thu, Nov 8, 2012 at 7:33:48 AM | Coloring an area, without coloring my furniture?
gebber
gebber Avatar
5 Stars: 4 Votes
choose edit family go to the 3D view.
Select the desktop and click Visibility settings here select the pickbox Plan/RPC.
Thu, Nov 8, 2012 at 7:39:19 AM | Coloring an area, without coloring my furniture?
petitmaire
Okay. I tried selecting and changing the visuability of the table top, and all the check boxes are checked and nothing changed. I am now having trouble copying/moving these particular tables between floors. Have you experience with a family being locked to something instead of the reference floor? (hope this makes sence)
Thu, Nov 8, 2012 at 8:43:51 AM | Coloring an area, without coloring my furniture?
petitmaire
I get this warning when i try to copy between floors "There are identical instances in the same place. This will result in double counting in schedules."
Thu, Nov 8, 2012 at 1:02:03 PM | Coloring an area, without coloring my furniture?
You get that warning because the object is being pasted in the same place.  Use copy to clipboard - paste aligned to selected levels.
Fri, Nov 9, 2012 at 7:46:22 AM | Coloring an area, without coloring my furniture?
petitmaire
I figured something out, so it works.. ish.
but thank you guys so much for taking the time to help me out Smile
Coloring elements - plan view
Sun, May 28, 2006 at 2:13:40 AM
topography
Mon, Dec 5, 2005 at 9:33:12 PM
UNDERSTANDING space and space tags - Green coloring
Fri, Jan 27, 2012 at 11:25:14 AM
Color Schemes
Wed, Jun 3, 2015 at 3:15:19 PM
Parametric Exit Sign
Mon, Apr 14, 2014 at 11:04:10 AM
Page generation time: 0.5205
