34 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line locking
Tue, Nov 6, 2012 at 6:03:01 PM | Line locking
spacey
I get unpredictable behaviour when trying to lock lines. I will try to attach a file to demonstrate this.
In the file, in the Ref.Level floor view:
when I drag the  reference plane on the left, it moves the nearby diagonal line with it, without changing the angle of the line,  changing its position relative to the reference plane Wall face
When I drag the right reference plane, it moves the right end only of the right hand line, changing the angle of the line.
Both of these lines appear to be only locked to the Centre/Front/Back reference plane, so why are they behaving differently?
Sun, Nov 25, 2012 at 2:48:19 PM | Line locking
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I had a look at your family and it's clear what you say. You need to understand the basics and you are short a few reference planes.
1. Start with the correct family template file.
2. Create the reference planes
3. Create dimensions and  paramters.
4. Flex the model
5. Lastly, add the linework. Your family is simply not ready to have linework. The lines and solids ALWAYS goes in last. NEVER FIRST.
Do not start drawing any lines or solids etc until all the reference planes are behaving as expected.
Hopes this helps.
See attached image with suggested reference planes and dimensions that need to be turned into parameters.
Erase all your lines and start again using the steps above. Should only take 15-20 minutes to make this profile family.
Locking columns to a detail line
Fri, May 25, 2007 at 12:12:14 PM
locking detail line to ceiling for elevation view.
Fri, Jan 23, 2009 at 4:00:43 PM
Families - Locking complex geometry
Thu, Dec 4, 2014 at 10:48:23 AM
Locking toolbars
Sat, Sep 27, 2008 at 10:28:06 AM
locking linked files in mep2011
Mon, Mar 19, 2012 at 11:16:20 PM
Page generation time: 0.8158
