50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Editing end of canted wall condition
2 Posts No Rating |
Good Day,
First off, thank you for this resource. I am learning Revit, and it is very useful.
I have a condition in a building where a wall extends through the roof, cants, and becomes a skylight.
To start the wall I used a mass and then the walls from faces command.
In the attached image you can see the end condition is leveled off; I want it to square off with the stud.
Any ideas how I can achieve this? Thanks!
Hi
You can do this with a void-family you use to cut the wall. Create a Generic Model Family with the void-shape you need in your project, remember to tick 'Cuts with Voids When Loaded' on. Then you can use it in your project to cut walls with the cut command in Modify.
Or create it as an in-place family.
Sofus
2 Posts No Rating |
Thank you Sofus for the reply. Would an in place family be the most appropriate response to this particular situation? I am very new to Revit and still learning the best tools for particular situations.
Nick
In-place family is perhaps easier to use, but gives you one solid element.
The void falily gives you a true wall with layers.
Which method depends on what you want to do with the wall, and how detailed your project is.
How do i make a Canted Wall? |
Sat, Sep 1, 2012 at 1:47:24 AM
Canted wall? |
Thu, Sep 21, 2006 at 2:08:32 PM
wrap exterior face of wall at ends as an instance not a type parameter |
Thu, Mar 27, 2008 at 9:22:30 AM
If/Then & Yes/No Parameter Condition |
Fri, Aug 29, 2014 at 2:18:54 PM
Canted walls |
Mon, Jan 19, 2004 at 2:02:17 PM
Members: | 2017311 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
