59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> setback structure
Fri, Nov 2, 2012 at 12:04:00 PM | setback structure
jimshunk
hi.
this is my first thread on revit city, and i apologise in advance if this is not the right place for my thread.
i am in my final year studying architectural technology and i have designed a 5 storey building and each floor
is set back 1 metre from the one below it. the structure will be made with steel beams and columns, with
concrete slabs poured in each bay.
my question is can this be done, which i presume it can, but as i am not an engineer, i am unable to say how it works.
i have a small understanding on point loads and forces acting on a beam.
anyway, as i said, each floor has a concrete slab. this has to be supported by a column, but with my design, the column is just resting on the beam below, and then it steps out aginb for the next load.
i have attached a 2D drawing of what the structure will look like, so i hope you can understand what i mean.
as i said, i am an architecture student, and this isnt really an issue to work out loads, but as i design a building i like to
have an idea of how the structure works.
i can use revit and position beamsn and columns and all looks weel in 3D, but will it actually work??
will it need very thick beams?
sorry for the long post, and i know it is a bit away from an actual revit question, but thought someone here could
ease my mind.
thanks in advance,
Fri, Nov 2, 2012 at 12:15:13 PM | setback structure
Probably not as you show it.  The reason why it won't work is that 1/2 the floor loads from every level ends up resting on the first level's beam.    You can do something like this on one level but the exterior column on the next should be continuous all the way down.  Depending on your skin, that cloumn might axtually be at the location of your fouth floor column and the 4th floor cantelevers out to the position you want for the 3rd floor.  << No 3rd floor perimeter columns.
Fri, Nov 2, 2012 at 12:31:45 PM | setback structure
jimshunk
thanks for your reply.
i understand what u mean, and it did cross my mind that it would be too much of a load.
i have attached another drawing.
do you think this would help?
Fri, Nov 2, 2012 at 12:47:48 PM | setback structure
Not much... Do the next floor down ....not the top floor.
Fri, Nov 2, 2012 at 1:18:10 PM | setback structure
jimshunk
so this will be sufficient?
Fri, Nov 2, 2012 at 1:50:49 PM | setback structure
That has a better chance of working.
Fri, Nov 2, 2012 at 2:14:15 PM | setback structure
jimshunk
thanks for your help. i can see now myself that it would have a better chance of working.
Fri, Nov 2, 2012 at 6:24:24 PM | setback structure
Manny
3.5 Stars: 6 Votes
It does work, all you have to do is make your bearing beams bigger as you go higher.
Fri, Nov 2, 2012 at 6:46:03 PM | setback structure
jimshunk
Thanks for your reply. So are u saying that more or less all those 3. Structure would work? after more research myself, I have
Found out that I could use a slanted concrete column structure?  Then the cantilever would be the same on each floor. Would I be right in saying that?
how can I make an arc setback in a revit wall, not openings.
Mon, Oct 25, 2010 at 1:26:49 AM
Wall opening setback for door jamb
Tue, Apr 30, 2013 at 8:43:07 AM
HM Door/Window Setback Puzzle
Fri, Sep 28, 2012 at 10:42:12 AM
Wall Sweep Setback
Wed, Dec 16, 2009 at 1:12:37 PM
door frame off-set
Wed, Mar 11, 2015 at 7:42:21 AM
Page generation time: 0.5164
