76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Side Covering
Thu, Nov 1, 2012 at 9:13:53 PM | Side Covering
mcbrian25
Hello fellow Reviters! Im pretty new in using the software and I am wondering if you can help me with my dilemma I am facing at the moment. Is there a simple and fast way of wrapping around a covering on wall exterior when the floor is raised above the ground level? I have attached a scanned file of the drawing. Thanks in advance!
Fri, Nov 2, 2012 at 5:58:28 AM | Side Covering
4 Stars: 203 Votes
"Stacked Walls" is the answer... Look your HELP menu: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0356-Working_356
Fri, Nov 2, 2012 at 2:52:36 PM | Side Covering
mcbrian25
Thank you very much! :-)
walls covering pipes
Tue, Dec 13, 2011 at 11:36:10 AM
Filled Region Not covering wall surface pattern
Mon, Apr 25, 2022 at 8:09:10 AM
white lines
Wed, Mar 14, 2007 at 3:08:06 PM
Wall sweeps are covering Door Trim
Sun, Jun 17, 2007 at 2:18:18 AM
12
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:59 AM
Page generation time: 0.5584
