43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Ignoring grid lines between independent structural systems
Thu, Nov 1, 2012 at 11:15:52 AM | Ignoring grid lines between independent structural systems
csteude
I'm currently working on a project with two separate structural grids: one for an existing building and another for a new high-rise I'm designing on top of it. Due to the nature of the two buildings' interaction, both new and existing are within the same model. The problem is that when I place walls in the new building, the temporary dimensions measure to the nearest datum point. This is as often a grid line for the building below as it is to a nearby wall.
Is there a way I can tell Revit to ignore a set of grid lines? Or since the existing building columns will not be changing, am I better off deleting these grid lines and limiting the grids to the new construction? Any advice anyone may have would be helpful. Thanks.
Chris
Thu, Nov 1, 2012 at 12:00:32 PM | Ignoring grid lines between independent structural systems
Put the grids on two seperate worksets and turn off the unwanted for normal work.
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:14 PM
how do you make structural beam systems visible.
Fri, May 8, 2009 at 4:34:31 AM
grid lines extend beyond detail
Mon, Jul 20, 2009 at 2:06:00 PM
Multiple bays of Framing for Structural
Tue, Mar 30, 2010 at 6:45:10 PM
Manipulate Structural Grid in Architectural model
Mon, Nov 14, 2011 at 4:11:47 PM
Page generation time: 1.1894
