60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> Multiple Curves and Angles with Sweep
Wed, Oct 31, 2012 at 5:08:11 PM | Multiple Curves and Angles with Sweep
khart11
I am attempting to create a reception desk that has multiple curves going in different directions, but am having trouble creating one path in 3D that I can sweep. Is there a good way to do this? I have attached an image of the desk built in sketchup, but would like to build in in Revit so I can edit in here and it will not have as many lines. Any suggestions would be appreciated. Thank you!
Wed, Oct 31, 2012 at 5:47:28 PM | Multiple Curves and Angles with Sweep
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
very difficult shape in revit. perhaps massing which I don't use much, or see attached might give you some ideas.
Wed, Apr 17, 2013 at 2:42:28 AM | Multiple Curves and Angles with Sweep
ronmalit
5 Stars: 3 Votes
hi
sorry for playing around your reception counter
basically i used all the forms (solid/void) for you to visualize on how to do it inside family editor (generic model>furniture)
hope it helps
** dont be mad, i dont have much... i am homeless
Thu, Jun 6, 2013 at 11:38:07 PM | Multiple Curves and Angles with Sweep
angelbalilz
angelbalilz Avatar
is this issue still active? that can be done by sweap, sweap blend and shear effort,.. there are shape that cant be done in a single component,.. devide the shape to a small parts to make it possible.
Edited on: Thu, Jun 6, 2013 at 11:38:59 PM
Mon, Jun 24, 2013 at 1:34:46 PM | Multiple Curves and Angles with Sweep
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Depending on how far down the rabbit hole you want to go, you can create quite a bit in one form.
http://www.revitcity.com/gallery.php?action=view&gallery_id=22224
Hopefully this link remains active and isn't dynamic...
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
angles wall sweep for a baseboard
Mon, Dec 2, 2019 at 3:52:26 PM
Can't create sweep
Tue, Jul 31, 2012 at 11:02:14 AM
Multiple Profiles in a Sweep
Fri, Nov 2, 2007 at 6:02:35 PM
creating double door with multiple swings
Fri, Oct 31, 2014 at 1:44:28 PM
blending curves
Mon, Oct 13, 2008 at 12:22:38 PM
Page generation time: 0.5692
