111 Users Online (109 Members):
Forums >> Revit Structure >> Technical Support >> Room name override in schedule
5 Posts No Rating |
I am making a door schedule and want to override my room name in the schedule without changing it on my plan. Because of space limitations i have some corridors labeled as "corr." on the plans but would like to have them read "corridor" in the schedules. Is there a way to make a text override parameter for the room? I know I could make a text parameter and type all the room names in but there has to be (i hope) a way to just have an override option.
Thanks!
You can't over-ride a room name in a schedule.
We have two different room tags...actually several types. One tag reads the normal room name. A different tag type reads an abbreviated room name. We change the tag in plans where required but use the full name in schedules.
Just assign a new shared parameters to rooms in the project and modify your tag adding a type that swaps out the name for the shared parameter Abbrev. Name ... NOTE - You have to create the shared parameter first.
Override a Field in Schedule |
Thu, Feb 4, 2010 at 10:29:42 AM
Find a specific room in the room schedule |
Thu, Jul 4, 2019 at 2:08:03 AM
Embedded window schedule in Room schedule |
Thu, Nov 19, 2015 at 1:03:49 AM
automating door schedule ( From room # To Room #) |
Thu, Jun 20, 2019 at 2:14:07 PM
Room finish Schedule showing Deleted Rooms |
Wed, Aug 26, 2009 at 3:56:37 PM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
