47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Syncronizing Issue
Wed, Oct 31, 2012 at 8:39:09 AM | Syncronizing Issue
ChrisBryant
One of the Revit computers in my office seems to have some problems syncronizing with the central model. Sometimes, changes that were made aren't getting into the central model or being saved to the local model after syncronization. It has happened at least twice in the last week or so. We had no issues with it for several months before hand, so I don't think it is a user error issue.
Has anyone run into anything similar? I really don't know where to start looking for a solution.
Wed, Oct 31, 2012 at 9:10:05 AM | Syncronizing Issue
If a save to central/save local does not give you an error, then it should be correct but the user has to wait for the final save local to finish.  (The standard save to central is a 3 step process.)  You might try doing it separately doing a save local first, then save to central only, then save local again.
We do the above process when there may be potential network problems.  The save local first means you don't loose your work.
Fri, Nov 2, 2012 at 8:38:38 AM | Syncronizing Issue
ChrisBryant
Alright, thanks. That at least gives us something to try. We have been having networking issues lately, so that may have been the problem.
Issue date vs Revisions
Tue, Oct 14, 2008 at 10:10:37 AM
Drawing Issue Record
Wed, Sep 6, 2017 at 8:52:11 PM
mullion issue
Wed, Jul 13, 2011 at 1:07:50 PM
Render Issue
Mon, Aug 24, 2015 at 7:01:39 AM
Revit slow down... and "locked"?
Tue, Aug 3, 2010 at 2:55:06 PM
Page generation time: 0.4583
