Forums >> Revit Building >> Technical Support >> Decal Bump Pattern
8 Posts No Rating |
Hello,
I am trying to create a 'raised' decal on a building face. I have tried manipulating the bump pattern and bump amount in the Decal attributes without success. The text box that describes the Bump Pattern states that you can "use dark and light areas of the image to specify raised and lowered areas..". This is exactly what I'd like to do, but I'm obviously missing something. Is there a straightforward way of doing this? See attached.
thanks
Are you just trying to have the letters raised or the whole decal? If you are trying to raise the whole decal you will have to add a small portion of wall to the back of the decal. Decals are still 2D objects and wont show an actual depth. You could also use Model Text to get some depth to your letters
8 Posts No Rating |
I was hoping to raise just the letters. i like your suggestion about model text but would have to match font which may be custom in this case. that may be the way to go though
Here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=7980
You are using bumps in a manner they were not meant for. Sorry, but I don't think this will work. You can load a dwg into a family and use that linework to create a 3D element.
8 Posts No Rating |
Understood. Thanks for the feedback
Decal rendering |
Sun, Nov 9, 2008 at 4:02:33 AM
My bump lines are too thick and heavy. [ 1 2 ] |
Thu, Aug 11, 2016 at 2:45:38 PM
21
Decal 2009 issue |
Sun, Nov 9, 2008 at 5:29:42 AM
Revit Architecture 2013 - Decal Tool not functioning |
Mon, Jan 13, 2014 at 10:18:31 PM
Decal Placement |
Wed, May 1, 2013 at 7:55:41 AM
Members: | 2126334 | Objects: | 23226 | Forum Posts: | 152296 | Job Listings: | 3 |
