43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Roof Plan fill patter orientation
3 Posts No Rating |
I am using revit architecture 12, im trying to create a roof plan. I have applied the standing seam metal roofing material, and used a texture pattern. Its all great in model. But i am preparing construction documents, and i cannot seem to get the fill patterned aligned properly on my roof plan. Its a hip roof and the fill pattern line should be vertical on two ends and horizontal on the opposite two ends of the roof. Am I missing something, do I have to fake it in my detail views with a filled region?
Use the "Align" tool.
Post some images so we can figure out what's the issue please...
![alfmedina Avatar](user_avatar/41302.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
Sounds like you are using "drafting" hatch pattern, which won't align with the faces of the roof. Make sure the hatch pattern is of "model" type, not "drafting".
Planta1 Revit Online Consulting | info@planta1.com |
Fill Patterns disappear in Roof Plan |
Thu, Jan 7, 2010 at 2:08:39 PM
Revit 9.1 Detail compontent fill pattern orientation |
Tue, Jan 14, 2014 at 4:18:30 PM
surface patter visibility in plan vs elevation |
Mon, Sep 2, 2013 at 2:05:07 PM
Tower Roof...Fill Pattern |
Fri, Jan 12, 2007 at 9:49:28 AM
Roof Plan Issues- lower roof showing above upper roof |
Thu, Dec 10, 2015 at 3:10:46 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
