Forums >> Revit Building >> Technical Support >> solid walls transparent to curtain walls and railings in back..
6 Posts No Rating |
Hello, I have a very annoying visual display issue: my solid walls, floors are transparent to curtain walls or handrails that are actually in the back of them. I have tried to adjust the visual graphics and theres no transparency set to my walls or floors. and seems that only handrails and glass curtain walls show through the solid floors/walls. ive attached a screenshot so someone can please help me out.
6 Posts No Rating |
also im using 2013 version
Graphic card issue. Update your Drivers, also, turn off "Hardware acceleration" parameter.
6 Posts No Rating |
Thanks you !!
the hardware acceleration worked, however made it a bit slower if i update my drivers and turn the acceleration back
on will it work better?
6 Posts No Rating |
works great thank you !
6 Posts No Rating |
okay it worked great for a few hours now its again screwed up and even worse since its showing all the line work behind solid object
Still graphics issues. Delete the 3D view and create a new one.
Note - Colors and shadows use a lot of memory as does constantly spinning the model in 3D. If you have a limited system, you may want to limit these activities.
Non Transparent Curtain walls in 3D View????????? |
Fri, Sep 11, 2009 at 1:48:59 AM
Floors and walls being transparent in 3D view |
Thu, Nov 12, 2020 at 2:52:53 PM
11
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:48 PM
Curtain walls |
Mon, Nov 7, 2011 at 10:28:34 AM
Transparent Railings |
Fri, Mar 18, 2011 at 11:29:36 AM
Members: | 2101706 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
