Forums >> Revit Building >> Technical Support >> model too slow/dragging when exporting
11 Posts No Rating |
Hi, what could cause a model to drag? I've worked with projects upwards from 200,000SF, and when exporting the model to CAD, it took little time. There were a ton of linked files and families.
This particular model is only 25,000SF, and there are more groups than families. The furniture plans have the most grouped objects, and those are definitely slower than the floor plans. There are not many (if any) linked files. Is there a "process of elimination" checklist which could help me to determine what is causing this model to drag. It is especially ornery when exporting to ACAD.
computer stats: 3.40Ghz, 2GB RAM, RADEON X300 video card
Almost certainly it�s your groups! They slow down the view quite a bit� I had drawings with maybe 50 or so drafting lines grouped, it really slowed down my display, I think because it is trying to regenerate the whole group� hope a fix will be out in 9
Thanks a bunch for the insight!
Slow Model? – How to Increase Revit Performance |
Thu, May 23, 2013 at 2:22:22 PM
slow model...help! |
Fri, Feb 17, 2012 at 8:09:29 AM
Walkthrough Export is very slow |
Fri, Feb 13, 2009 at 2:44:46 PM
Selective 3d Exporting |
Thu, Feb 12, 2009 at 1:53:21 AM
Exporting REVIT 8 Model to Photoshop7 |
Wed, May 18, 2005 at 11:50:04 PM
Members: | 2114928 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
