38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Metal-Stainless steel- Dacor brushed.jpg missing
Wed, Oct 24, 2012 at 5:59:18 PM | Metal-Stainless steel- Dacor brushed.jpg missing
hgrimberg
Every time I try to do a Kitchen interior elevation I get the warning saying "The render appearence image is missing: Metal-Stainless steel- Dacor brushed.jpg.
I looked all over on every appliance and I can't find any that is using this material. How can I get this .jpg and add it to the material on the materials list?
Thu, Oct 25, 2012 at 7:40:23 AM | Metal-Stainless steel- Dacor brushed.jpg missing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You will have to find where you saved the .jpeg then go into your material editor and apply it to the material that is using the .jpeg.  My guess would be someone moved the .jpeg to a different folder or erased it all together so in that case you may need to find a new one.
Thu, Oct 25, 2012 at 9:21:53 AM | Metal-Stainless steel- Dacor brushed.jpg missing
hgrimberg
Well, it doesnt find the .jpg in revit 2010 nor in 2012, so, I don't think someone moved the file... Besides, where can I get the .jpg file? I searched on the internet but couldn't find it.
Thu, Oct 25, 2012 at 9:32:39 AM | Metal-Stainless steel- Dacor brushed.jpg missing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I don't think someone moved the file" Well if you are getting the warning that is saying
"The render appearence image is missing: Metal-Stainless steel- Dacor brushed.jpg." Then the file was either moved or erased.
The material you re talking about does not sound familiar as a material that came with Revit.  Was this a material that you created?
If you open the material editor and go to the material in question you will see the image (or missing image) and there will be a driver path underneath it where the jpeg as originally "suppose to be".  If you cannot find it you will just have to find a new picture that has the look you are trying to achieve.
Thu, Oct 25, 2012 at 9:34:18 AM | Metal-Stainless steel- Dacor brushed.jpg missing
I don't believe that this is a standard material.  It was probably defined in the family.... So where did you get that?  If someone made it there then they have the jpg.  Otherwise, you will have to assign it a different or new material.
Thu, Oct 25, 2012 at 12:02:12 PM | Metal-Stainless steel- Dacor brushed.jpg missing
hgrimberg
Yes, maybe it was something I took from revitcity and it came without the .jpg. I searched on the Dacor website, but didn't find it.
Thank you.
daylight portals 0
Mon, Jul 12, 2010 at 2:01:05 AM
slope metal roof deck
Thu, Jul 21, 2011 at 9:40:40 AM
Steel material showing gray when rendering
Mon, Mar 16, 2015 at 1:39:02 PM
metal building question
Fri, Dec 20, 2013 at 8:39:29 PM
How do I split this object without the void appearing in my second object?
Wed, Nov 24, 2010 at 9:38:58 PM
Page generation time: 0.8785
