49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Tapered Circular Column
Tue, Oct 23, 2012 at 3:54:23 PM | Tapered Circular Column
anishshahs
Hi,
I am a new Revit user and working on a project where I need to do a tapered circular column (greater diameter at the base and a smaller diameter at the top).
There is probably a really easy way to do this but any direction or help would be great
Thanks.
Tue, Oct 23, 2012 at 4:06:12 PM | Tapered Circular Column
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Create a column family using a blend extrusion.  You could also check the download section on here, just search tapered column
Tue, Oct 23, 2012 at 4:06:27 PM | Tapered Circular Column
Either create a family that is a vertical extrusion - blend or an in-place family of the same process.
Gheese ... tea is way ahead of me again.
Edited on: Tue, Oct 23, 2012 at 4:07:01 PM
Tue, Oct 23, 2012 at 4:08:25 PM | Tapered Circular Column
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Ha I just noticed how close those 2 post were apart!  I'll let you take the next one WW! Winking
Tue, Oct 23, 2012 at 4:10:30 PM | Tapered Circular Column
anishshahs
Thank you! That was quick.
Revit newbie - Tapered circular column will not attach top/base properly
Thu, Aug 22, 2013 at 5:26:47 PM
Parametric Circular Column...Offset issues
Tue, Jul 17, 2012 at 12:42:39 PM
Tapered Columns
Mon, Nov 13, 2006 at 11:49:36 AM
tapered beam
Wed, Apr 13, 2011 at 4:29:38 PM
TAPERED CRAFTSMAN STYLE COLUMN
Sat, Jul 1, 2006 at 10:25:56 AM
Page generation time: 0.4294
