45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Printing PDF Line Drawing - Wont show surface textures
6 Posts No Rating |
Hi All,I have a problem. I am trying to print a perspective view into a PDF in hidden line view.I have a brick wall and a slate roof, neither of the pattern details are showing up in the PDF Print and I can't seem to work out why....If I zoom in further then you can start to see the brick and it will then print the pattern in the PDF However, I need a zoomed out version and I don't feel I am too far away that shouldn't be able to see the bricks if you get me.Could some please advise me as I can't seem to find a forum with the answer.Cleo77
This is often the case when the pattern gets too small to print. You might try a different pdf printer but I doubt that will do it.
You could also scale your view up then if printing the PDF, print to a scaled size.
Revit 2013 textures not printing to pdf or paper |
Mon, Feb 3, 2014 at 2:15:52 PM
Printing |
Tue, Oct 5, 2010 at 6:38:41 PM
3D PDF inclusive material textures |
Tue, Jun 25, 2013 at 2:28:04 PM
problem printing line weight to pdf |
Tue, Sep 30, 2014 at 3:31:49 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
