58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> joint slant and vertical mullion
Tue, Oct 23, 2012 at 3:34:17 AM | joint slant and vertical mullion
TT65
hi,
i have create my curtain wall using mass on my building. how do I joint the vertical mullion and slant mullion. Is there another way to draw it. please help.
Tue, Oct 23, 2012 at 7:18:27 AM | joint slant and vertical mullion
You could create a special trapezoidal mullion that exists in your vertical system.  The slanting system would have none and would be held back appropriately.  Or, you could just do an in-place family.
Tue, Oct 23, 2012 at 9:05:44 PM | joint slant and vertical mullion
TT65
hi wwhub, thank you for your help. I have manage to fix the problem or error. The vertical mullion and the slant wouldn't joint because I place the mullion on the curtain system using all grid. I then removes the unwanted horizonal mullion.at the joints thinking it wall joints automatic like basic walls.
The way should be done is by placing the mullion individually on each grid line on the curtain system. I placed mullion and the vertical and slant panel sparately in 3D view and it joint automatically. see results
Joining Roofs with different slant angles
Fri, Apr 19, 2013 at 10:19:06 AM
how can we creat whatever mullion bar outside horizontal and vertical bar!!
Wed, Sep 23, 2009 at 4:35:54 AM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:11 PM
23
Create NEW Curtain Wall Mullion FAMILY
Fri, Mar 13, 2015 at 9:59:36 PM
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:09 PM
Page generation time: 1.5753
