44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> phasing
Mon, Oct 22, 2012 at 1:17:34 PM | phasing
michB
Revit 2013
I have recieved a plan from an architect that is all in one phase when our building requires phasing-years of contruction/additons.  When it is already completed without phasing how do I speparate the building into phases.  When I highlight area the properties panel does not give me this option for all items only some.
I hope that's clear.  Thanks.
Mon, Oct 22, 2012 at 1:21:46 PM | phasing
You have to establish the phase first.
Mon, Oct 22, 2012 at 1:28:38 PM | phasing
michB
Really? with all this program does ....the drawing can't be re-phased to suit the new plan owner's needs??
Mon, Oct 22, 2012 at 1:37:03 PM | phasing
Did you read my answer?
I said the phase has to be created first.  You can't assign anything to a phase that doesn't exist.  Revit just can't read your mind.
Mon, Oct 22, 2012 at 1:42:47 PM | phasing
michB
It read to me that the phasing had to br created first ie: beginning of the project ie: no turning back. Apologies if my answer was taken wrongly....clealy was.
I have created all the phases required....I have used phasing quite a bit.
Tue, Oct 23, 2012 at 7:42:24 AM | michB
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting michB from 2012-10-22 13:42:46
Phasing does not have to be created at the being of a project. It can be Phased anytime.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Oct 23, 2012 at 8:20:22 AM | phasing
michB
Thank you.
I have a building that has been created under one phase (existing).  Each wing of this school was built in different years and I was looking for an easy way to place those additions in the appropriate phases that I have already created.  I have highlighted the area and using the properties window chosen each element to change their phase however some elements do not allow me to do this.
I have carried on and done it manually so to speak....doing each item as allowed.  I had hope there was an easier way that I wasn't figuring out on my own because the program does so many things with little effort that this did not seem consistent.
Please forward to WWhub.
Phasing - Building Already Done but Dind't Set up Phasing
Tue, Dec 15, 2009 at 7:40:43 AM
Phasing moved to Visibilty/Graphic
Wed, Nov 18, 2009 at 4:11:57 PM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:01 PM
PHASING
Tue, May 20, 2008 at 1:57:26 PM
Maintain phasing when copying elements - how?
Tue, Mar 10, 2009 at 10:02:09 PM
Page generation time: 0.8270
