Forums >> Revit Building >> Technical Support >> Door Swing Question
34 Posts No Rating |
I need help trying to set a parameter to a door swing. I would like the Door Swing in plan view to be able to adjust so that way certain door swings will not overlap each other. Thanks!
Draw reference lines and then aling and lock your symbolic lines and add an angle dimension parameter to it, set it by instance so that you can change one door without changing all of the others.
I tried that and i keep getting a Constraints not satisfied error. Here is what i have set for the angel paramter.
Did you align and lock the END of the symbolic line to BOTH the horizontal and vertical reference lines?
Yes i did, does it matter if they are Ref. Lines or Planes? What else do you think it could be?
Yes it has to be a reference line. Add your family on here and I will see if I can take a look at it.
There should be one of these in the download section that you can develop from if that helps.
Edited on: Fri, Oct 19, 2012 at 11:42:44 AM
Anything with Angle related constraints needs to be Reference Lines. Not Reference Planes.
Here is the door family, sorry it took awhile for me to get it to you. Thanks for your help
Yes i used Ref. Lines when i aligned the symbolic lines.
Just wondering if you were able to figure out the problem with that door swing issue?
47 Posts No Rating |
See if this helps any.
http://www.augi.com/library/creating-door-swing-angles-in-revit/
You may download this one from this site to see if it helps.
08-Openings, 08 10 00 -Doors & Frames, Adjustable Hollow Metal Door for CMU Wall - Revised.
