80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall dimensioning
Mon, Jan 16, 2006 at 10:35:07 PM | Wall dimensioning
unicorn
Hi I have built a model with walls showing true thickness... that is, say a 120mm stud wall, 10mm internal plaster wall, and 35mm external cladding. I did this so that i could assign materials to my walls which could be rendered in a presentation model. But when dimensioning the walls for the working drawings, the dimensions pick up everything, which is not what i want. I want the dims to only pick up the stud thickness... Is there any way to get the dimension lines to only do this? Anyone with adivce on this?
Mon, Jan 16, 2006 at 11:07:49 PM | RE: Wall dimensioning
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you doing a chain dimension? regardless, once clicking on the dimension, some options will appear on top, choose to core face from the drop down menu, you might also have to change the geometry of your wall (in edit wall properties) to make sure that only the stud wall is in the core boundry and the cladding and plaster are on the outside... HTH
Integrator
KarelCAD
Thu, Jan 19, 2006 at 5:28:49 PM | RE: Wall dimensioning
unicorn
Eldados, thanks, couldn't find this post after i had posted it and therefore thought i had lost it... i also wasn't notified by email of your reply, which usually happens so didn't know you had replied.
Revit 2008 - Dimensioning Curtain Wall
Tue, Feb 19, 2008 at 5:26:47 PM
Need help dimensioning this wall!
Sat, Jul 25, 2009 at 10:56:27 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:56 PM
Revit 2010-Dimensioning
Wed, Jan 20, 2010 at 10:47:17 AM
Dimensioning Angular Walls
Mon, Jan 16, 2006 at 6:34:08 PM
Page generation time: 0.9231
