48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can´t rotate sloped roof in elevation .. please help
Thu, Oct 18, 2012 at 7:39:27 PM | Can´t rotate sloped roof in elevation .. please help
anapaularg
using revit 2012.
I created a roof using roof foot print with slopes that have different degrees. what I want to do is to rotate it like the image explains. I am doing it with slopes to keep it planar so I can later make a ceiling using the slope planes. I hope i am explaining myself... it seemed like a simple thing to do but it has taken me hours to solve.
thanks a lot,
Fri, Oct 19, 2012 at 3:59:52 AM | Can´t rotate sloped roof in elevation .. please help
4 Stars: 203 Votes
You can't do that (rotate) but you can change the offset of the edges, in sketch mode you can select the edge you want then in properties you can change the "offset" parameter.
Fri, Oct 19, 2012 at 9:07:30 AM | Can´t rotate sloped roof in elevation .. please help
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
I don´t think this is possible with Roof by footprint with a different offset for one of the short sides, due to the slopes in all the sides. I think, a possible solution is a family with reference points and surfaces, then load into project, and do roof by face.
Planta1 Revit Online Consulting | info@planta1.com
Fri, Oct 19, 2012 at 11:20:06 AM | Can´t rotate sloped roof in elevation .. please help
anapaularg
Hi thanks for the help,
Yes I tried to offset the edge and it did not allow me to create the roof.
I am going to try the family and roof by face idea, although I am not very familiarized with the roof through faces.
I tried this other option of making a planar foot print roof and then adding diviosn lines and modifying the points but then my problem is the planar surfaces, is there anyway to keep them planar? attached an image of what I mean.
thanks a lot for the help,
Fri, Oct 19, 2012 at 11:51:34 AM | Can´t rotate sloped roof in elevation .. please help
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, your approach of a flat roof with modify sub-elements, add point, different elevations, etc. can get the job done. Just watch for the thickness of the roof, that sometimes is not mantained constant with this method. But, other than that, this can be a good and easy solution in this case.
Fri, Oct 19, 2012 at 12:10:26 PM | Can´t rotate sloped roof in elevation .. please help
anapaularg
yes my only problem is I can[t keep them planar so if later I want to make a ceiling under it, it doesn't let me, I thought I had it but if the face is not planar then I can not choose it as a plane. so later I can't use it for structure etc. cause it doesnt recognize it as a face.. aa it seems like such a simple thing but I cant find a way to do it. Is there a way around the planar stuff??? Am i explaining my self?
thanks again
Fri, Oct 19, 2012 at 12:52:07 PM | Can´t rotate sloped roof in elevation .. please help
anapaularg
SOLVED IT,
just triangulated the planes to make them planar! Smile gracias!
Sloped roof surface pattern grayed.....Revit 2015
Thu, Jan 15, 2015 at 1:48:15 PM
adding crickets to a sloped roof structure
Mon, Oct 16, 2017 at 9:28:29 AM
Metal roof deck on sloped roof
Wed, Oct 21, 2009 at 3:33:17 PM
sloped flat roof - Q2of2
Mon, Sep 11, 2006 at 5:25:29 PM
Problems with Sloped Glazing Roof
Thu, Jun 26, 2008 at 11:00:25 AM
Page generation time: 0.6686
