44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Routing Preferences - Pipe MEP
Thu, Oct 18, 2012 at 6:49:10 PM | Routing Preferences - Pipe MEP
malagon03
say, I have a pipe run that bends at 88 degrees and then bends again at 45 degrees (same Diameter). if I check the types selected by my routing preferences, both of my bends are shown by the diameter, and THE SAME Family Type is listed for both bends when the 45 type is different to the 88 type. how can I set my routing preferences on pipes for Diameter and ANGLE variations??
Routing preferences junction problem
Thu, Apr 19, 2018 at 6:08:46 AM
How to load Routing prefrennces at once?
Fri, Jul 29, 2016 at 1:35:41 PM
Video Tutorial - REVIT 2013 MEP Hot and Cold Water Pipe Routing
Thu, Nov 1, 2012 at 12:40:04 PM
Pipe size
Fri, Jan 21, 2011 at 11:27:02 AM
REVIT MEP PIPE WORK
Wed, Sep 19, 2007 at 10:12:34 AM
Page generation time: 0.4455
