Forums >> Revit Building >> Technical Support >> nested family
18 Posts No Rating |
I am new to Revit,please help how to do nested family & parametric.
thank u
Check out Mr. Spot's tutorial on this subject:
http://www.revitcity.com/tutorials/arrays_and_nested/
Tom
24 Posts No Rating |
Great tutorial. I'm having a problem, though. (In my case I'm working with doors - trying to nest a door panel component into a frame family). When I go to place the door panel in the frame family, it only lets me move the panel left to right, instead to toward the front or back of the wall (I need to dimension in the latter direction), despite the fact that I've set the Left vertical reference to Defines Origin in both the component and the family. It keeps placing the door panel component in relation to the center of the wall in the Frame family, and only lets me move it left to right... What am I doing wrong? I would really appreciate any help with this - I'm so close to making use of the powerful nested family - I can't fail now!!!
Well, I didn't figure out how to change the origin of my door panel made from a door template (wall-based), but I did find a work-around: I remade my panel from a generic family template and then nested it into my frame family (made from a door template, wall-based), and now I have the freedom to move the panel in any direction within the frame family.
Your second method is actually the prefered method. Any time you need to make a component for a nested family, start with a generic model family and just change the category to the particular family type you need. As for your other; this was probably caused from having the "panel" associated with a work plane. I believe it will do this automatically.
nested family rotation |
Tue, Sep 3, 2013 at 1:25:42 PM
scale nested family within a family (2017) |
Wed, May 3, 2017 at 5:28:44 PM
Nested Family Count in Table |
Mon, Jan 15, 2018 at 11:47:53 AM
Locking nested families? |
Wed, Aug 27, 2008 at 12:23:10 PM
13
Nested family always vertical? |
Mon, May 16, 2011 at 2:55:03 PM
Members: | 2115099 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
